As i saw the schematic, NPN transistors are used in the circuit to drive the relays. Did you intend to ask "can i use any PNP transistors?" If that was your question, using PNP in place of NPN will compliment the present state of the relay.newbie111 said:I would like to try this connection in the diagram
my q is can i use any npn transistors?
Thanks
