Which metal layers we use for Clock Tree Synthesize?.
kumar_eee
Advanced Member level 3
Bangalore,India
CTS Route Metal
Let say, the top most metal is 7.
Now, my question is which metal layers we use for CTS route?.
Re: CTS Route Metal
According to me for CTS higher metal layer is used. since clock goes to every where and it switches fast so resistance of metal should be as slow as possible and capacitance also, since higher metal layer are thicker and wider it is best suit for CTS.
Let others flash on this.
Shitansh Vaghela
Re: CTS Route Metal
Generally, the top-most layer is reserved for the power routing. The layer that is immediately below the top-most metal layer can be utilized for clock routing. I am not sure whether clock routing can share the top-most layer with power routing. Can somebody clarify this?
Re: CTS Route Metal
Yes, clock routing can share the top-most layer with power routing.
for e.g : out of 7 LM we can use 6&7 for power routing and 5,6&7 for clock routing instead of 4&5 for clock routing. So we can have more routing resources for signal routing.
Jit
Re: CTS Route Metal
in soc encounter it uses metal 3 and 4 by default in cts
