Which Linux version support IC610 Cadence?
ldhung
Member level 3
Member level 3
Could you please tell me that IC610 Cadence could install on which Linux OS: Fedora Core 3,4,5 or 6? Or other Linux OS else ?
Re: Help IC610 on Linux
Fedora Core 3,4,5 or 6 is OK.
Help IC610 on Linux
Oh, it is great. Thanks.
which one your using ?
I suggest you using RedHat Enterprise version.
Hello,
base on my experience. Cent OS is the best, I have installed without any problem.
CentOS is an alternative OS for RHEL ( as recognized by cadence). I also tried in fedora 11 but seem but i have failed.
regards,
Kumar
Hello,
Could you please specify which version of CentOS have you used and which version of Cadence? at the moment I'm getting crazy to install it...
one more query on this thing can i install it on my rhel 5 ,,i have tht version only,,or i have to go to rhel4.7 .,,,,,,,,,,,,,,pls reply i m a newbie,,thnx in advance
IC6 Cadence supports RHEL 4, RHEL 5, SLES 10, SLES 11 platforms, because you can try install ic on rhel 5.
Here suppoted platform for each cadence product.
thnx for response i tried but , i think cause i m new to linux ,,m not been able to install it ,,can u give me a step by step process frm the scratch,,,,,,,,,,,,,,,,,i will be very thnkful if u just made a video of installing ic610 & send it to my mail...pls help me i m in a real needy situation i am trying to install it frm weeks,,,& even i have reinstalled my linux 2 -3 times ,,, so if u can use ur screenrecodera make a video & send it to my mail"er.abhinav.saxena.3@gmail.com" i will be very thankful................pls help
---------- Post added at 15:35 ---------- Previous post was at 15:34 ----------
i have cadence ic610 iso ,,& it has two folders ,,,,,,,,ic610_lnx86 base which have 5 cdroms in it and the other is ic 610 lnx86isr200612081658 which have 3 cdroms in it ,,but i dont know how to install please give me a step by step procedure...........
