JimLo
Junior Member level 3
could anybody tell me the differences among following relays:
PCB?
GP?
HF?
Solid Stat?
Low Signal?
MOS-FET?
typically , what are they used for???
if i just want a 3v signal to control a dual switch between two outputs using the relay, which should have low state-on resistance with peak current of 1 or 2A. could you tell me which kind of above relays should i use?
thank you very much for your help, my friend.
PCB?
GP?
HF?
Solid Stat?
Low Signal?
MOS-FET?
