Which is the fasest logic for gray2bin convertor?
elektrom
Full Member level 2
Full Member level 2
gray2bin
I'm designing async fifo 512x32 on virtex II and found that the criticial path is in gray2bin converter. Below is gray2bin function that i used, Do you know any faster logic?
function GRAY2BIN( GRAYSLV : std_logic_vector ) return std_logic_vector is
variable BINSLV : std_logic_vector(GRAYSLV'range);
begin
for I in GRAYSLV'range loop
if I = GRAYSLV'left then
BINSLV(I) := GRAYSLV(I);
else BINSLV(I) := GRAYSLV(I) xor BINSLV(I+1);
end if;
end loop;
return BINSLV;
end function GRAY2BIN;
gray2bin.c
Sorry. Actually, I need the fastest logic for gray counter. Traditional architecture is
1) gray2bin
2) binary increment
3) bin2gray
Does anyone know anyother technique?
try this :
library IEEE;
use ieee.std_logic_1164.all;
use ieee.std_logic_arith.all;
Entity gray_cnt is
generic (
cnt_size : integer range 0 to 15 := 8
port(
rst : in std_logic ;
clk : in std_logic ;
cnt : out std_logic_vector (7 downto 0)
end gray_cnt;
architecture rtl of gray_cnt is
signal counter : std_logic_vector (cnt_size-1 downto 0);
signal tog : std_logic;
constant zero : std_logic_vector (cnt_size-1 downto 0) := (others => '0');
begin
gray:process(clk,rst)
variable i : integer ;
begin
if (rst = '0') then
counter <= (others => '0');
tog <= '1';
elsif clk='1' and clk'event then
tog <= not tog;
if tog = '1' then
counter(0) <= not counter(0);
else
if counter(0) = '1' then
counter(1) <= not counter(1);
end if;
for i in 2 to (cnt_size-1) loop
if counter(i-1) = '1' and counter(i-2 downto 0) = zero(i-2 downto 0) then
counter(i) <= not counter(i);
end if;
end loop;
end if;
end if;
end process gray;
cnt <= counter;
end;
sucesfully synthesized with ise
:wink:
port
cnt : out std_logic_vector (cnt_size-1 downto 0)
end gray_cnt;
to BlackJack :
oops :oops:
if it's the only bug in my design, that's not too bad :wink:
