Which is the current limit of a usb of a PC?
xxtigerxx
Advanced Member level 1
Greece
i want to supply a device 12V 200mA for the usb.
can i do it?
of course i will use a step up conventer or a charge pump to make 5Volt USB to 12Volts.....
THX
If I remeber correctly the maximum current limit is about 500mA at 5V, so in ur case assuming no losses Pin = 5 * 500mA = 2.5 Watts
Pout = 12 * 200mA = 2.4 watts
mmm very critical so I would suggest using two usb ports instead of one. I think some of the new usb devices use this way to overcome power limitation
BR
Adel_48
Under all conditions you are guaranteed to get 5V @ 100mA, but if you are connected to a PC (connected to the wall outlet) you can negotiate for upto 500mA, but if you are connected to a laptop then it may or may not give you the extra current.
- Jayson
The maximum is 500mA, if your application is over the maximum, it should be better to apply by a power supply.
