Which instruction SEROUT or HSEROUT to use for PIC16f876?
debutpic
Member level 4
Member level 4
Hi all
With pbp (melabs), I can use instruction SEROUT or HSEROUT with one 16f876,what instruction is the best for this device?
HSEROUT Vs Serout
If the PIC that you are using has a hardware usart you can use the HSEROUT command. Look up the data sheets from microchip. If you have the option to use the HSEROUT command definately use it. The same goes for the HSERIN command.
They work
Pic 16f876 have hardware usart and the both cammand work with it
regards
Fragrance
Yes you should use Hserin or Hserout (Hardware Serial out)
The routines for serin or serout make hardware emulation and are time consuming. The routines for Hserout only have to write some register at time to send data because the usart do all.
neb,...
Serout does not use UART Protocal I believe.
