Which equipment is used to generate test vectors shifted into the scan chain?
akrlot
Member level 3
Member level 3
hi;
my question is: which equipment is used to generate test vectors shifted into
the scan chain?
thx
ATPG question
snps teramax
    akrlot
Re: ATPG question
akrlot said:
hi;
the scan chain?
thx
It's tools, tools generate ATPG pattern => test machinie => fed into chips => get the shift-out series.
Tools includes
1. Teramax
2. Syntest
3. Mentor fastscan
ATPG pattern by different ventor varies in the length.
    akrlot
Re: ATPG question
im talking about equipment thats implemented on the chip.
thx
Re: ATPG question
Scan Chain are often multiplex with other function PAD for test.
Besides, JTAG protocol is also often used. but can not perform a parallel test and the speed is limited
    akrlot
Re: ATPG question
Your question isn't very clear.
In traditional SCAN/ATPG methodology, the test-patterns come from an external device (test-console.) The on-chip hardware is very limited -- 1) some I/O drivers to receive the incoming pattern, and transmit the observed response. 2) SCAN registers to allow the external-console "set" the state of the entire chip (usually by means of serial scan-chains.) The SCAN registers can either be multiplexed D-flipflops, or level-sensitive latches, the foundry tells you which they support.
More recently, ASICs have gotten larger and larger (millions of gates), so test patterns have grown correspondingly. At some point, the time it takes to sweep a full ATPG-pattern through the device-under-test becomes uneconomical. So EDA-companies have come up with an alternative approach -- logic BIST (built-in-self-test.) In this methdology, the DFT-tool inserts an intelligent state-machine + control-logic into your design-netlist. The embedded state-machine generates the test-pattern, exercises the logic, then measures the logic's response to determine PASS/FAIL. This approach has the advantage of using very little data transmission over the I/O, and this also reduces test time. But of course, the logic-BIST controller adds a lot gates by itself (area overhead.) There are other variations on logic-BIST, but they all try to accomplish the same thing -- minimize the amount of external pattern-data needed to test a chip. (Basically, logic-BIST puts 'intelligence' in the chip. Traditional BIST keeps intelligence out of the chip, in the external tester-console.)
    akrlot
Re: ATPG question
ATPG Generater generates the test vectors
but BIST approach seems to answer you better.
IST aproach uses LFSRs etc to generate the test patterns in the chip itsef.
    akrlot
Re: ATPG question
The scan vector is generated by ATPG tool (like tetramax).
The vector (in STIL format) then can be used by the IC tester, to test the chip.
    akrlot
ATPG question
yeah, most test are based on ATPG pattern, function patterns are develop for testing the uncovered aspects
    akrlot
