Which corners do DAC circuits pass ?
ilter
Member level 4
Member level 4
Dear all,
I am simulating my dac. I have a question. In general, which corner do my circuits pass?TT ,FF,FS,SF,SS or temperature 0° ,25°,50°,75° or voltage.
In genearal, which corner do it pass about DAC? I am not experience.Thanks.
Re: Simulation question
I think you should first design using TT at 25. Once you got satisfying results you can perform corner simulation.
The best would be to check everything, but it might take time, so personally I would do:
FF, 0°C, VDD+0.2 (if 3.3V -> use 3.5V)
SS, 75°C, VDD-0.2
it generally gives a good idea.
You can find a more detailled discussion here:
you must make your circuit pass all corners.
Simulation question
In fact, not only the corner you provided, but also the corner about Res and Cap.
SS, 75°C, VDD-0.2
Dear sunking,
If my voltage is 1.8V. what voltage do I use? 2V or 1.9V
Thanks.
Simulation question
Start with TT @ 25*C but leave error margin. In the end you'll have to do all corners!
Simulation question
If your voltage is VDD, you should do at VDD+/- 10%.
Simulation question
FF+low Temp+low vol
ss+hi Temp+high vol
tt
SF,FS,
try to get the worst case
