amitjagtap
Full Member level 5
hi all,
We are designing a board in which we required different clocks like 100MHz,125MHz, 25MHz, 19.2, 12, & 24 MHz etc. I need to know, which solution is better among the following....
1) Using separate Xtal oscillators in a board or
2) Using a chip, which can generate all above required clock frequencies.
What are the advantages and disadvantages in 1 & 2.
pls, answer this query....expecting from experts...
thanking you:idea:
thanking you:idea:
