which book is good for dsp??
amolbook
Junior Member level 2
digital signal processing sanjay k mitra
im new to dsp... i hav some knowledge abt signals & systems...
which book is good for me to start with???
ramesh babu dsp
Hi friend,
Signal & system By Oppenhium & Willsky ( Good for Time Representation, Fourier series & Transform-continous & discreate, & Z-transform)
Poakris-Good for Filters & Time representation, DFT
digital signal processing by ramesh babu
for starting the best book is digital signal processing by prokis and next you can refer discrete time signal processing by Opphenhium and shwfer.
dsp ramesh babu
Hello friend,
I hope depending upon the course structure different books are good. But according to my knowledge the book oppenheium & willsky is the master piece in digital signal processing. Both oppenheium & prokris helps to build the fundamental of the beginner in dsp. It clears the concepts regarding the signal systems.
But people can follow different books of depending upon their course structure.
Thank You,
malaya@iitg.ernet.in
dsp by ramesh babu
Don't search for a book, Proakis and Manolakises book is a DSP Bible, There are a few newer and more moden books but for a beginer I'ld say that the first few chapters of the proakis book are sufficient
descrete signal processing by openhaum schaffer
Discrete Signal Processing by Oppenheim and Wilkski is thew best available book
digital signal processing ramesh babu ebook
I think for the beginer Digital Signal Processing by Ramesh Babu is the best book.Once you got the idea regarding it then go for Discrete Signal Processing by Oppenheim and Wilkski.
For problems you please refer Digital signal processing Scham's outline .
ramesh babu digital signal processing ebook
hi,
1st u should read the book of SCHAUM'S OUTLINE Series DSP.
Solve examples and also solve the solved problems.ok
Then read or consult any other book like PROAKIS and SCHAFER.
i think u better understand.
mitra oppenheim + google books
usman_star2 said:
hi,
anybody there gotta ebook for SCHAUM'S OUTLINE Series DSP ?
dsp - ramesh babu| exercise problems
Digital Signal Processing By
Iffechar
Is a very good to start
MUSSSST READ
~orfanidi/intro2sp/
Scientist & Engineer's Guide to Digital Signal Processing by Steven W. Smith
if u are new to dsp ramesh babu is better, and the best book is proakis,
Added after 2 minutes:
if u are new for signals&systems p.ramesh babu is better ,if u thorough with signals&systems proakis is best
dsp by ramesh babu
Proakis is the best book I have ever seen. But Oppenheim is an divine book for us. For MATLAB implementations Mitra will be an excellent choice. I have this 3 books all. I recommend you to use these both:) You will get best results...
where can i find dsp by ramesh babu
the best known book is oppenheim (its directly to higher level) if u're able to manage its good
first try sanjit k mitra or ifeachor
dsp by p.ramesh babu text book for free
proakis is the best book for beginners,......althouh u can refer dsp by oppeinheim schaffer also at the later stages....
dsp+ramesh babu
I think if you want to have a basic information about dsp you should use SCHAUM'S OUTLINE .it has examples and easy to understand
ramesh babu dsp
Rick Lyons "Understanding Digital Signal Processing" is quite good.
dsp text book by ramesh babu
Hi
These 3 books are good for dsp
1 dsp by mitra
2 dsp by proakis
3 dsp by oppeheinm
All these books are available on eda board.
openhaum dsp
