mdturan20002000
Newbie level 5
I will make an antenna at VHF.ıt isn't important what frequency but must be between vhf . which antenna would you advice?
Thanks in advance.
Thanks in advance.
hi ,u can use log periodic antenna ,that its charactersitic remain same appro. at all band,(g,d),and has high gian,easy to match with 75 ohm with no matching techniques else the feeding methodmdturan20002000 said:I will make an antenna at VHF.ıt isn't important what frequency but must be between vhf . which antenna would you advice?
Thanks in advance.
