Where to start designing in ASIC?
dev
Junior Member level 3
asic designing
where to start in asic design, I have done a projeact in vhdl in chip programming,can any one give me guidance in related field and about asic designing,links where i can find help
asic designing
I think the vhdl coding is a starting step of asic design. You can reference the book of aisc primer for more information of that. I do not know which field you will be interested in, analog or digital, so after you read the book I recommend you will get the answer. This book can be download from this forum.
Re: asic designing
I am interested in digital and i have done a project in arbiter chip degining and hope to get along in the field and know better
asic designing
Try to find a design flow from some vendors.
asic designing
you may also google some tutorial on the web.
ex. many university courses
Re: asic designing
You can find some ASIC building blocks introduction there. ASIC design contains countless sub-topics.Good luck!
Re: asic designing
The steps fro asic designing
specification
HDL coding
Synthesis with (Technology library)
STA
place and route
mask design sign off
ok bye
asic designing
Look here:
Re: asic designing
hi,
ASIC design is divided into two parts. Front-end and back-end.
Front-end comprises of
a) Design -entry which can be HDL(Verilog or VHDL) or schematic.If schematic generate a netlist of it and append to your final netlist.
b) Then you synthesize the design from RTL to gates.You specify the constraints and synthesize the design according to those constraints.Then you check if the timing is met.This will be done by the synthesis tool itself, or you can use some stand alone timing analysis to do that.
c) Then you may add scan to it (for testability and controllability of the circuit after fabrication).
d) Then you generate ATPG vectors for detecting faults on chip.
Back-end
a) You do the P&R of the complete design
b) Then you do the timing analysis of post-layout netlist to make sure you have the netlist meet the timing.
c) You do physical verification and then you can generate a SPICE netlist and run SPICE on the design if you wanted.
Thanks,
