Where to buy a research purpose generator??
yzou_ua
Member level 5
Member level 5
Generally, it is quite common for "motor" available commercially. Is it ok to be used as a generator, i.e. be drived by another motor to generate electricity ??
If not, where I can buy a research-purpose GENERATOR ??
Why don't you try using B2B websites as these are one of the best options to look for as you find a wide range of suppliers & exporters from all across the world.
MODERATOR ACTION: Signature is removed
yes you can use a motor like a generator. the real generator is actually built a little different for optimization purpose.. but the motor as a generator will work just fine.
Mr.Cool
Reactions: yzou_ua
    yzou_ua
