Riyad
Junior Member level 1
Hi, I am a bit confused on where the source on a PIFA antenna is situated exactly!
I know, there is a feeding wire passing through the ground plate and end on the radiating plate. But If I want to simulate the fields in FDTD, where do I place my excitation pulse? Is it in between the ground plate and radiating plate, just where the feeding wire touches the radiating plate or just where the feeding wire touches the ground plate?
Thanking you in anticipation...
