Where I can get LDV documnet
darkslate
Junior Member level 1
I installed the LDV4.1 on linux,
But there is no document.
where I can get LDV4.1 documents?
Where can you find the LDV for linux?
I need it.
:eek:
In c*dence's ftp, you can find a larger size file of ncsim4.1...,
it comes with doc, just download it, then link doc to this release.
run "cdsdoc" to view it.
Just type cdsdoc in linux command shell !
under $install_dir/doc
check it, they are mixed html/pdf files!
Search what you want in this forum, you will have that download info.
install the document
You can select to install the document when the windows push.
