Where I can find USB kernel
luben111
Advanced Member level 1
UK
cp2101 8051f320
Hello,
I can't figure out from where to take USB kernel. I have to make a project with USB in HOLTEK part and I don't want to rediscover the wheel.
Thank you
Luben
HI
If all you need is connect your controller via USB go to www.silabs.com and get
CP2101 chip for converting RS232 <-> USB as simple as it sound
All the best
Bobi
Hello,
SP2101 is too expensive solution for my purposes. I found uP that are several times cheaper then Silicon labs one and has USB and there are lot of free resources to put my code there - see HOLTEK 82K96.
And yes, I agree that Silicon labs USB - serial converters are really excellent... just too expensive and there is no place to put my code. I used uP 8051F320 from Silicon labs and it has plenty memory after you add the USB kernel, unfortunately it's 3 times more expensive then HOLTEK.
best regards
Luben
USB kernel? or a USB communications layer?
I'm sorry.... USB communications layer.
I need the layer that communicate with the PC (handshaking, packages, etc.)
Thank you
Luben
you know, this USB thing JUST seems to be too complex, once you've sent the host the necessary descriptor blocks, it will provide you with a device class driver, so for many standard applications, like modems, audio devices, video capture and mass storage, you do not NEED to develop any kind of PC-side driver...
I think that for low data-rates (a maximum of 64kbytes/sec, unidirectional) a simple CDC enumeration would do the job...
