Where I can find the schematic for 68hc11/68hc05?
cdance
Newbie level 2
Newbie level 2
68hc11/68hc05
Where I can find the schematic for a programmer for mcu 68hc05/11 but not this with one max232 a little more complicated ? 8O
My best regards.
hai,
u can easily find using google
in 68hc811 with max232 and imagecraft s/w.
Re: 68hc11/68hc05
Why you don't want to use this MAX232 programer. If you don't use this read in tech. docs for this CPU - you will need from external EPROM to load code to mikrocontroler. This CPU is self programable and you have to load code to some memory - for example 27c256 with another programer which is dificult.
Regards
Re: 68hc11/68hc05
I thank you for the answer
I look for another programmer if exist one because this is a little unstabile,and I have destroyed some mcu with him.
My best regards....
