Where does this emitter resistance equation come from?
zhi_yi
Full Member level 4
Full Member level 4
anybody, please tell me where does this equation come from??
re' = 25 mV / IE
thank you very much
Re: emitter resistance
KT/q is 25mv
regards
it is the equation of the t-modek of bjt transistors when used in common base mode
You can get the answer from the following link:
thanks all for the helps, but i still confused with what is k, what is T, an what is q, please explain it and derivate the equation
thanks....
I cannot deduce the formula, but:
k=Boltzmann's constant; k=1.380658E-23 [J/K]
T=absolute temperature T=273.15+t[°C] [K]
q=electron's charge q=1.6E-19 [C]
So at room temp (300K), this quantity kT/q (thermal voltage) works out to about 25.89mV. So if the temperature is less than 300K (27°C), it will be closer to 25mV.
Usually, I consider it 26mV.
The formula you are referring to represents the input impedance of a transistor in CB. It it calculated as the ratio of voltage (thermal voltage) over current.
If you read carefully the paper posted by MRFGUY, you will see where it comes from.
