E-design
Advanced Member level 5
I was wondering about when you install some trial, demo or some share ware programs etc. When you uninstall (supposed to remove the files they planted on your PC) the program it is well known that some file/s are left behind so that when you try and reinstall the program it greets you with "This program has expired or was installed already" or something in the like. Is there a certain place where this "tracking" file/junk is stored? Is it only in the registry or in the Windows, System, System32? In the past I had some limited success by climbing into the regedit and removing traces of leftovers of the uninstalled program. That does not always work and besides is risky to fiddle with the registry (make backup first).
Utilities like Norton, CleanPC, Registry Medic does not seem to sniff out the planted file or entry.
Does anyone knows about a utility that can actually remove all this junk that gets left behind on your PC. I am sure over time it must accumulate and surly must slow down performance and cause freeze-ups etc.
Also how do you remove the entry in Window's uninstall list when it reports that there was an error in the uninstall process which now leaves you with the program (or part of it) missing but still shows up in the list?
I am asking the above questions not for illegal purposes and are not referring to any specific program, but more for interest and for the fact that I hate unnecessary junk left behind on my PC.
Thanks E
Thanks E
