skatefast08
Full Member level 4
I cant seem to find 0402 ceramic capacitors, inductors, and resistors in Eagle. Where would I get the library, if it isn't on Eagle? :bang:
usually a resistor/capacitor.. comes with many different packages.
either you choose the packaged when you ADD the device
or you use CHANGE / PACKAGE / click_on_device to change the package afterwards.
Klaus
https://www.ultralibrarian.com/
Register with an simple e-mail then you can download schematic symbols and footprints depending on your preferred tool.
You don't need a library for 3.2pF, 1.7pF, 1.5nH...
* Just add the device
* choose the correct package
* use the VALUE command and type in "1.7pF" ... or any other value
Theses are very basics about EAGLE.
Better consult a EAGLE tutorial.
Klaus
Klaus
You are looking for is a standard package, which could have even been used another 0402 component as a template; in any case, I did not spent too much time to make a search filter at a specific supplier, and see that there are houndred of options. The first one redirected to the SnapEDA website, another source of footprints for many CADs:but I could not find 0402 SMD inductor
https://www.digikey.com/products/en...ntity=0&ColumnSort=0&page=1&cad=1&pageSize=25
Anyway, the link that BigBoss posted earlier (Ultralibrarian) has what you want, but you seem to have overlooked it.
wouldn't it be important to be able to right click on the component and be able to view properties? Well, my component I loaded onto Eagle will not bring up any options.
