where could I finde out the result?
jluhzw
Member level 5
Member level 5
Hangzhou China
when we simulatie the circuits in Hspice ,we could find out the concrete results in the *.lis file,such as the data of the nodes' voltage or paths' current.However when I do the simulation in the spectre, I don't know where is the result data.Only do I find out the results in the wavescan or waveform.Does it have the result data file in the spectre,such as the *.lis in the Hspice?If it does,where could I find that files.
I have found the way to look the result
In the wavescan form, you select a trace,and ciick the Trance menu
Trace->save save the ASCII file filename
and use the vi open the filename in the directory where you save the filename
now you will get the result in the concrete datas
