Code C++ - [expand] 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119 120 121 122 123 124 125 126 127 128 129 130 131 132 133 134 135 136 137 138 139 140 141 142 143 144 145 146 147 148 149 150 151 152 153 154 155 156 157 158 159 160 161 162 163 164 165 166 167 168 169 170 171 172 173 174 175 176 177 178 179 180 181 182 183 184 185 186 187 188 189 190 191 192 193 194 195 196 197 198 199 200 201 202 203 204 205 206 207 208 209 210 211 212 213 214 215 216 217 218 219 220 221 222 223 224 225 226 227 228 229 230 231 232 233 234 235 236 237 238 239 240 241 242 243 244 245 246 247 248 249 250 251 252 253 254 255 256 257 258 259 260 261 262 263 264 265 266 267 268 269 270 271 272 273 274 275 276 277 278 279 280 281 282 283 284 285 286 287 288 289 290 291 292 293 294 295 296 297 298 299 300 301 302 303 304 305 306 307 308 309 310 311 /* File: Serial.h Contains: Asynchronous Serial Driver (.AIn/.AOut/.BIn/.BOut) Interfaces Version: Technology: System 7.6+ Release: QuickTime 6.0.2 Copyright: (c) 1985-2001 by Apple Computer, Inc., all rights reserved Bugs?: For bug reports, consult the following page on the World Wide Web: [url=https://developer.apple.com/bugreporter/]Bug Reporting - Apple Developer[/url] */ #ifndef __SERIAL__ #define __SERIAL__ #ifndef __MACTYPES__ #include "MacTypes.h" #endif #if PRAGMA_ONCE #pragma once #endif #ifdef __cplusplus extern "C" { #endif #if PRAGMA_IMPORT #pragma import on #endif #if PRAGMA_STRUCT_ALIGN #pragma options align=mac68k #elif PRAGMA_STRUCT_PACKPUSH #pragma pack(push, 2) #elif PRAGMA_STRUCT_PACK #pragma pack(2) #endif enum { baud150 = 763, baud300 = 380, baud600 = 189, baud1200 = 94, baud1800 = 62, baud2400 = 46, baud3600 = 30, baud4800 = 22, baud7200 = 14, baud9600 = 10, baud14400 = 6, baud19200 = 4, baud28800 = 2, baud38400 = 1, baud57600 = 0 }; enum { stop10 = 16384, stop15 = -32768L, stop20 = -16384 }; enum { noParity = 0, oddParity = 4096, evenParity = 12288 }; enum { data5 = 0, data6 = 2048, data7 = 1024, data8 = 3072 }; enum { aData = 6, /* channel A data in or out (historical) */ aCtl = 2, /* channel A control (historical) */ bData = 4, /* channel B data in or out (historical) */ bCtl = 0 /* channel B control (historical) */ }; enum { dsrEvent = 2, /* flag for SerShk.evts */ riEvent = 4, /* flag for SerShk.evts */ dcdEvent = 8, /* flag for SerShk.evts */ ctsEvent = 32, /* flag for SerShk.evts */ breakEvent = 128 /* flag for SerShk.evts */ }; enum { xOffWasSent = 128, /* flag for SerStaRec.xOffSent */ dtrNegated = 64, /* flag for SerStaRec.xOffSent */ rtsNegated = 32 /* flag for SerStaRec.xOffSent */ }; enum { ainRefNum = -6, /* serial port A input */ aoutRefNum = -7, /* serial port A output */ binRefNum = -8, /* serial port B input */ boutRefNum = -9 /* serial port B output */ }; enum { swOverrunErr = 1, /* serial driver error masks */ breakErr = 8, /* serial driver error masks */ parityErr = 16, /* serial driver error masks */ hwOverrunErr = 32, /* serial driver error masks */ framingErr = 64 /* serial driver error masks */ }; enum { kOptionPreserveDTR = 128, /* option bit used with Control code 16 */ kOptionClockX1CTS = 64 /* option bit used with Control code 16 */ }; enum { kUseCTSOutputFlowControl = 128, /* flag for SerShk.fCTS */ kUseDSROutputFlowControl = 64, /* flag for SerShk.fCTS */ kUseRTSInputFlowControl = 128, /* flag for SerShk.fDTR */ kUseDTRInputFlowControl = 64 /* flag for SerShk.fDTR */ }; enum { sPortA = 0, /* Macintosh modem port */ sPortB = 1, /* Macintosh printer port */ sCOM1 = 2, /* RS-232 port COM1 */ sCOM2 = 3 /* RS-232 port COM2 */ }; typedef SInt8 SPortSel; /* csCodes for serial driver Control routines */ enum { kSERDConfiguration = 8, /* program port speed, bits/char, parity, and stop bits */ kSERDInputBuffer = 9, /* set buffer for chars received with no read pending */ kSERDSerHShake = 10, /* equivalent to SerHShake, largely obsolete */ kSERDClearBreak = 11, /* assert break signal on output */ kSERDSetBreak = 12, /* negate break state on output */ kSERDBaudRate = 13, /* set explicit baud rate, other settings unchanged */ kSERDHandshake = 14, /* superset of 10, honors setting of fDTR */ kSERDClockMIDI = 15, /* clock externally on CTS with specified multiplier */ kSERDMiscOptions = 16, /* select clock source and DTR behavior on close */ kSERDAssertDTR = 17, /* assert DTR output */ kSERDNegateDTR = 18, /* negate DTR output */ kSERDSetPEChar = 19, /* select char to replace chars with invalid parity */ kSERDSetPEAltChar = 20, /* select char to replace char that replaces chars with invalid parity */ kSERDSetXOffFlag = 21, /* set XOff output flow control (same as receiving XOff) */ kSERDClearXOffFlag = 22, /* clear XOff output flow control (same as receiving XOn) */ kSERDSendXOn = 23, /* send XOn if input flow control state is XOff */ kSERDSendXOnOut = 24, /* send XOn regardless of input flow control state */ kSERDSendXOff = 25, /* send XOff if input flow control state is XOn */ kSERDSendXOffOut = 26, /* send XOff regardless of input flow control state */ kSERDResetChannel = 27, /* reset serial I/O channel hardware */ kSERDHandshakeRS232 = 28, /* extension of 14, allows full RS-232 hardware handshaking */ kSERDStickParity = 29, /* use mark/space parity */ kSERDAssertRTS = 30, /* assert RTS output */ kSERDNegateRTS = 31, /* negate RTS output */ kSERD115KBaud = 115, /* set 115.2K baud data rate */ kSERD230KBaud = 230 /* set 230.4K baud data rate */ }; /* csCodes for serial driver Status routines */ enum { kSERDInputCount = 2, /* return characters available (SerGetBuf) */ kSERDStatus = 8, /* return characters available (SerStatus) */ kSERDVersion = 9, /* return version number in first byte of csParam */ kSERDGetDCD = 256 /* get instantaneous state of DCD (GPi) */ }; struct SerShk { Byte fXOn; /* XOn/XOff output flow control flag */ Byte fCTS; /* hardware output flow control flags */ unsigned char xOn; /* XOn character */ unsigned char xOff; /* XOff character */ Byte errs; /* errors mask bits */ Byte evts; /* event enable mask bits */ Byte fInX; /* XOn/XOff input flow control flag */ Byte fDTR; /* hardware input flow control flags */ }; typedef struct SerShk SerShk; struct SerStaRec { Byte cumErrs; /* errors accumulated since last SerStatus() call */ Byte xOffSent; /* input (requested to be) held off by xOffWasSent or dtrNegated or rtsNegated */ Byte rdPend; /* incomplete read pending in I/O queue */ Byte wrPend; /* incomplete write pending in I/O queue */ Byte ctsHold; /* transmit disabled by hardware handshaking */ Byte xOffHold; /* transmit disabled by XOn/XOff handshaking */ Byte dsrHold; /* transmit disabled: external device not ready */ Byte modemStatus; /* reports modem status according to SerShk.evts */ }; typedef struct SerStaRec SerStaRec; #if OLDROUTINENAMES /* ********************************************************************************************* */ /* The following constant names have been retired in favor of standard, more descriptive names. */ /* You can still compile old code by defining OLDROUTINENAMES. There were several constants that */ /* were formerly available that have been removed, as they are now regarded as either private or */ /* unsupported. We advise that you stop using any constants that are not defined in this file. */ /* ********************************************************************************************* */ enum { serdOptionClockExternal = kOptionClockX1CTS, /* option bit used with Control code 16 */ serdOptionPreserveDTR = kOptionPreserveDTR /* option bit used with Control code 16 */ }; /* csCodes for serial driver Control routines */ enum { serdReset = kSERDConfiguration, serdSetBuf = kSERDInputBuffer, serdHShake = kSERDSerHShake, serdClrBrk = kSERDClearBreak, serdSetBrk = kSERDSetBreak, serdSetBaud = kSERDBaudRate, serdHShakeDTR = kSERDHandshake, serdSetMIDI = kSERDClockMIDI, serdSetMisc = kSERDMiscOptions, serdSetDTR = kSERDAssertDTR, serdClrDTR = kSERDNegateDTR, serdSetPEChar = kSERDSetPEChar, serdSetPECharAlternate = kSERDSetPEAltChar, serdSetXOff = kSERDSetXOffFlag, serdClrXOff = kSERDClearXOffFlag, serdSendXOnConditional = kSERDSendXOn, serdSendXOn = kSERDSendXOnOut, serdSendXOffConditional = kSERDSendXOff, serdSendXOff = kSERDSendXOffOut, serdChannelReset = kSERDResetChannel, serdSet230KBaud = kSERD230KBaud /* set 230K baud data rate */ }; /* csCodes for serial driver Status routines */ enum { serdGetBuf = kSERDInputCount, serdStatus = kSERDStatus, serdGetVers = kSERDVersion }; #endif /* OLDROUTINENAMES */ /* The following interfaces are for the legacy high-level serial driver glue in the interface libraries of your development system. They merely substitue for the corresponding synchronous calls to PBControl and PBStatus. They have not been updated as the serial driver API has evolved. Take note: SerHShake does not support hardware input flow control. Use csCode 14. SerStatus returns only the first six bytes of SerStaRec (through xOffHold). */ #if CALL_NOT_IN_CARBON EXTERN_API( OSErr ) SerReset (short refNum, short serConfig); EXTERN_API( OSErr ) SerSetBuf (short refNum, Ptr serBPtr, short serBLen); EXTERN_API( OSErr ) SerHShake (short refNum, const SerShk * flags); EXTERN_API( OSErr ) SerSetBrk (short refNum); EXTERN_API( OSErr ) SerClrBrk (short refNum); EXTERN_API( OSErr ) SerGetBuf (short refNum, long * count); EXTERN_API( OSErr ) SerStatus (short refNum, SerStaRec * serSta); #endif /* CALL_NOT_IN_CARBON */ #if PRAGMA_STRUCT_ALIGN #pragma options align=reset #elif PRAGMA_STRUCT_PACKPUSH #pragma pack(pop) #elif PRAGMA_STRUCT_PACK #pragma pack() #endif #ifdef PRAGMA_IMPORT_OFF #pragma import off #elif PRAGMA_IMPORT #pragma import reset #endif #ifdef __cplusplus } #endif #endif /* __SERIAL__ */
