Where can I get information to implement a PLL programmable clock in virtex 5?
Cesar0182
Member level 5
Member level 5
Greetings ... comment that I need to implement a programmable clock based on a PLL with ISE 14.5 for the Virtex 5 family (similar to the following example https://www.xilinx.com/support/documentation/application_notes/xapp888_7Series_DynamicRecon.pdf) but I cannot find information about the address map. Can someone help me with this please, thanks in advance
Please see chapter 2 of the following Xilinx document:
Xilinx support forum discussion suggests that Virtex 5 dynamic PLL reconfiguration doesn't work reliably http://forums.xilinx.com/t5/FPGA-Configuration/Virtex-5-PLL-ADV-dynamic-reconfiguration/m-p/965921
For Virtex-5 PLL, this is no longer supported. PLL may get mulfunction in some rare case.
It's suggested that you use DCM if possible and the changeable params would be M and D. You will need to find some other way to work around this if you must get a phase-shifted clock.
That's probably the reason why no Virtex 5 PLL reconfiguration address map is published.
