Where can I find ULN2805?
BEA
Junior Member level 2
Hi all,
I'm using a ULN2803 in SO18 package. Need to use ULN2805 instead (3.3VDC). Does anyone know where I can find it ?
Or any better idea to drive 8x 12V relays with 3.3VDC.
/Regards BEA
uln 2805
The only major difference between 2803 and 2805 is the input resistor ..
They are both rated for Vin max of 2.4V ..
If you have problems with 2803 you may have the same problems with 2805 ..
Other option is to use discrete digital transistors (with build-in resistors) or popular 2N7000 FETs ..
Regards,
IanP
Re: ULN2805
The gnd pin wasn't soldered ok to the pcb!!!
Re: ULN2805
One must be a fortune teller to predict that ..
Regards,
IanP
