ScholarGypsy
Newbie level 5
I have the Mr. Circuit One book (see www.eki.com) with 30 projects, but I need to order all the components to build and solder the projects. As presented, these are only Breadboarding projects and I am teaching my Grandchildren and want the to solder on perf board.
The problem was I went to Mouser's website and for resisters, had to choose between about 15 different suppliers of Resisters. I figure I need about a Dozen resisters for each project, and also to have a ready supply of resisters for later projects.
The first resister was 10 Ohm. The first supplier I clicked on did not even make a 10 Ohm resister.
And how can I choose right from all of these types?
resistors smd resistors (4041)
metal film tht resistors (1897)
power resistors (1647)
carbon tht resistors (998)
resistor networks (385)
heating resistors (22)
fusible resistors (17)
I have to buy Four Each of everything for Four students in my house. Then I want extra. But I can go bankrupt
buying supplies and kits from some of these "Educational" houses.
I know not SMD, but.... aren't some of these clearly expensive for a simple educational project?
I felt discouraged right away and lost in this process. Clearly, some manufacturers probably produce such a high quality I don't even need it. But I don't know how to.
I assume that about everything for these little projects is about 1/4 Watt? in power rating?
Can someone advise me as to ordering in quantities of about 10 to 12 etc for all these compnents.
