Discussions about the development and use of software code for networking with the uC/OS real-time kernel. This is especially for embedded system developers working with the TCP/IP/PPP stack code hosted at
Try **broken link removed**
They have rabbit microcontroller modules, e.g. RCM220 or RCM3000. The software that comes with these modules is bundled with the ucos OS. You can implement multitasking/real-time/web-enabled application using these modules.
It's very cool.
Source Code
µC/OS-II comes with ALL the source code. In fact, the source code is probably the cleanest and most consistent code of any RTOSs. All services provided by µC/OS-II starts with the prefix 'OS'. This makes it easier to know that the functions refer to kernel services in your application. Also, the services are neatly grouped by categories: OSMbox???() relate to message mailboxes, OSQ???() relate to message queues, OSSem???() relate to semaphore management etc.
No Royalties
µC/OS-II is licensed on a per-product basis and allows you to sell any number of units of the licensed product. For more details, contact Micriµm.
Only the Premier version come with uCos. I probe some features of realtime and work fine. If you have the Dynamic C Premier, you can implement the realtime software without costs (royalties, etc). Regards.
