Davidy
Junior Member level 2
I doubt at what condition should I use hysteresis comparator. Is hsysteresis compulsory?
Now I use comparator to convert two anti-phase sin. waves from sensor readout circuits to a square-wave.
The sin. waves are with about 100-150mV peak-to-peak voltage and 8kHz frequency.
If I use a comparator with 10mV hysteresis voltage, the output of comparator will have about 5-degree phase shift, which is problem.
Can i don't use hysteresis? or should i use only 1-2mV hysteresis?
Thank you !
Thank you !
