When the FPGA is in SPI Master mode how does it take the data from the SPI Flash?
hithesh123
Full Member level 6
lax
When the FPGA is in SPI Master mode how does it take the data from the sPI Flash.
Usually SPI flash has commands access data in a specifica page/bank etc.
Re: SPI Flash-FPGA interface
Your assumption is right, any read or write operation has to use the respective commands. But what are you exactly asking about?
Hi;
If you mean boot from SPI (I mean your design is flashed in SPI and FPGA is configured by that SPI data)
FPGA has internal macros/hard coded SPI read/write functionalities. It is already put in FPGA by the manufacturer, you just need to configure bootstraps.
Hope helps
Okay. Before going thru the Flash datasheet, I thought the FPGA would be doing a simple SPI read.
Does he? If so, hardware configuration load or booting a soft processor image? There are many ways to access a serial flash from an FPGA, the built-in configuration controller is one of them. Why we need to gues when hithesh123 can easily post a clear question?
It actually does in some situations.
