When power on inverter such as 74LVT04, the output is high impedance or low?
EDA_hg81
Advanced Member level 2
when power on inverter such as 74LVT04, the output is high impedance or low?
Thanks.
Re: Question Inverter
while power on the output impedance of the inverter is zero since it is supposed to maintain its voltage value irrespective of the amount of current it sinks or sources.....
    EDA_hg81
If is low impedence, this means the voltage level of output during power on is zero.
Right?
how r u coming to that conclusion..
if the impedence of output is zero, it doesn't matter how much the corrent is going to flow, since the V = Current * impedance.
if impedence = 0.
then V = 0.
right?
what we are talking about is the output impedance of the circuit and output impedance is pictured as being connected in series with the output.... since in our case the circuit output impedance is zero the drop from the output to the circuit to the output that we get is zero, no matter how much current flows..... it doesn't mean the circuits output will be zero...
Regards.....
    EDA_hg81
EDA_81hg,
You might want to consider this way:
If the out put is high, say 3V, and output impedance is zero,
and if you put 1 kohm load, current will be 3mA.
If you put zero ohm load, current will be infinity.
Hope this helps.
S.H.
    EDA_hg81
Question Inverter
kindly help me 12vdc to 220vac 500watts up inverter circuit diagram send to my mail or show me
Added after 4 minutes:
please always mail me for assistant
Added after 2 minutes:
my e-mail is rielcom2000@yahoo.co.uk
Added after 7 minutes:
please send me this circuit diagram 12vdc to 220vac 500watts up
Added after 45 minutes:
If I use RC circuit to enlarge the power rising time to the inverter and the input rising time to inverter follows the I/O rising timing set by FPAG without RC power delay.
What is the result?
Some guy said if use this way the inverter can be damaged.
Thanks.
Added after 1 minutes:
Thank you all so much.
I understand it.
can you please specify what FPAG is... i dont remember having heard any term like that....
    EDA_hg81
Hi A.Anand Srinivasan,
it is Spartan 3.
XC3S1000 FTG256
