When I run Hspice, I have the following problem: no sh
danda821
Full Member level 2
Full Member level 2
hspice running -n
when I run Hspice, I have the following problem: no sh
Does anyone know what is wrong? Thank you
[help] Hspice installation
For RedHat or FC1,
1. Go to <$hspice_inst_dir>/bin/tcltk/RH72/
2. rm -rf tixwish
3. ln -s /usr/bin/tixwish8.1.8.3.1 tixwish
This should do it.
May try <$hspice_inst_dir>/bin/tcltk/linux/ if not working.
[help]run Hspice
Thank you, the problem is solved.
where could i get the linux version Hspice ? i only have a
version of 2001.2 but my license is for 2001.2 it could not boot up
Re: [help] Hspice installation
l can not open my Avanwaves???
Yes, because Hspice in Linux has not the component--Avanwave. So you have to install another waveform viewer to observe output results.
Good Luck!
Use Cosm0s Sc0pe waveform viewer. It is excellent tool
linux Hspice installation
[Hi,
I tried to run hspice in a linux box but got the error message "...libc++-libc6..." that I couldn't figure out what it means. Can someone help me?
thanks,
Contact Synopsys sale rep
