mssong
Junior Member level 2
I am aware of a technique to turn off the low-side MOS with zero current sensing to prevent reverse current in a buck converter.
Where will the reverse current that would not have flowed without this technique flow when the reverse current protection circuit is added? Will it flow to the output load or stay in the inductor?
Or does the inductor current decrease so that there is no reverse current?
I don't quite understand, can you show me the current waveform when the reverse current protection circuit is added?
