when I intialize block RAM and I want to use block RAM in a FOR I faced with this invalid memory name?
stackprogramer
Full Member level 3
Full Member level 3
when I initialize block RAM and I want to use block RAM in a FOR I am faced with this invalid memory name.
When I don't use RAM block array in For loop I have not any warning and readmemh works correctly...
WARNING: [Synth 8-2898] ignoring malformed $readmem task: invalid memory name [file.sv:50]
WARNING: [Synth 8-2898] ignoring malformed $readmem task: invalid memory name [file.sv:51]
module multiplier_core
  #(parameter WIDTH=64)
   (input clk, input reset,input [31:0] reg_user,
    input [32-1:0] config_tdata, input config_tlast, input config_tvalid, output config_tready,
    output [63:0] o_tdata, output o_tlast, output o_tvalid, input o_tready);
     reg signed [15:0] data_samples_i_buffer [1024:0];
     reg signed [15:0] data_samples_q_buffer [1024:0];
     reg [31:0] edgei_tbl_rom[0:1024];
     reg [31:0] edgeq_tbl_rom[0:1024];
     initial begin
          //Initial
            $readmemh("/home/sp/rfnoc-test/rfnoc/fpga/rfnoc_block_multiplier/1.hex",edgei_tbl_rom,0,1024);
            $readmemh("/home/sp/rfnoc-test/rfnoc/fpga/rfnoc_block_multiplier/1.hex",edgeq_tbl_rom,0,1024);
    ebd
     always @(posedge config_tvalid ) begin
        if(state==1)
        begin
           $display("-------Clock is triggerted...%0d ----",m);
            //Save samples in samples buffer
            data_samples_i_buffer[m]=config_tdata[15:0];
            data_samples_q_buffer[m]=config_tdata[31:16];
            $display("Sample %0d = %0d +i %0d",m,data_samples_i_buffer[m],data_samples_q_buffer[m]);
            if(m==1024) begin
              m=0;
            end else begin
              m=m+1;
            end
              // temp_i_mult_result_sum= edge_tbl_rom[j];
            for(j=0; j<1000; j=j+1)
                begin
              temp_i_mult_result_sum= edgei_tbl_rom[j];//(temp_i_mult_result_sum+data_samples_i_buffer[j]*edgei_tbl_rom[j]+data_samples_q_buffer[j]*edgeq_tbl_rom[j]);
                end
               // energy_factor=reg_user;//65536*20;
                multiplier_tdata=temp_i_mult_result_sum;
          temp_i_mult_result_sum=0;
        end
        else begin
        end
  end
        assign o_tdata = { 32'h00000000, multiplier_tdata};
        assign o_tlast = config_tlast;
        assign o_tvalid = config_tvalid;
        assign config_tready = o_tready;
endmodule
Please review the explanation about "malformed $readmemh task" in your previous thread.
O.K., "ignoring malformed" seems to refer to a different problem https://support.xilinx.com/s/article/62935?language=en_US
In my words, you are using the memory in a way, that no block ram can be inferred.
Block ram can be only accessed one memory address per clock cycle. In your code you are reading the whole ram in one cycle, this prevents generation ("inference") of block ram and makes $readmemh fail.
When I remove the for and I write this section instead for now it works...I don't think in the Reg array I have a limit in a clock......but
when I used even for i=1 or 2 I was faced with previous errors.
my question why when I used for with readmemh it doesn't work correctly? can any one guide me?
temp_i_mult_result_sum= edge_tbl_rom[j]+edge_tbl_rom[j+100];
           temp_i_mult_result_sum= edge_tbl_rom[j+1]+edge_tbl_rom[j+5]+edge_tbl_rom[j+7]+edge_tbl_rom[j+8];
     initial begin
          //Initial
    ebd
        if(state==1)
        begin
            if(m==1024) begin
              m=0;
            end else begin
              m=m+1;
            end
        end
        else begin
        end
  end
endmodule
Read about RAM inference capabilities and coding template in Vivado Design Suite User Guide https://docs.xilinx.com/r/en-US/ug901-vivado-synthesis/RAM-HDL-Coding-Techniques
A code as quoted above
reg [31:0] edge_tbl_rom[0:1024];
blocks RAM inference. edge_tbl_rom can be only implemented in core logic. Besides large resource requirements (30k registers respectively large amount of combinational logic) this also seems to prevent usage of $readmemh system task, thus your table isn't initialized as expected. Unfortunately Xilinx doesn't manage to give clearly understandable warning about it, but the quoted support article suggests that the "malformed" warning comes in this cases.
The RAM/ROM can be still initialized in HDL code (generated constants, case construct, whatsoever). If the table is representing a mathematical function, e.g. trigonometric, you can calculate it in HDL without using external tools.
