thanks above
So,without negative feedback,there will be no zero differential input signal even if A is infinite like the equations revealed,or the equations only are valid with negative feedback?
Or,in my another option,I see, Vo/Vi=(1/f )• (T/1+T), where f is feedback factor,T is the loop gain.So, the differential input signal of the opamp is Vi - (Vo•f),which gives
vi - vi•(T/1+T),and the final result is vi • (1/1+T).Then with infinite gain A,the T will be infinite and vi • (1/1+T) will be zero,and the virtual ground occurs when the non-inv. input is connect to ground.
Am I right?
