when do i need to use RS 232 ??
ebtehal younis
Newbie level 3
Newbie level 3
i've read about RS 232 and i'm not sure when to use it. i want to connect sensors to a pic MCU using SPI interfacing, so i need to use RS 232 between or not?
The RS-232 standard is an asynchronous serial protocol primarily used to establish serial communications between DTE and DCE devices.
For example between a MCU and a PC running an application.
The SPI protocol is a synchronous serial protocol primarily used to establish serial communications between a MCU and a peripheral device.
For example, between an 8051 variant and Real Time Clock (RTC) with a SPI interface.
They are normally never required to be implemented for the same interface.
You might use an RS-232 connection to transmit information to your PC, which originated from a peripheral device attached to your MCU via an SPI interface.
BigDog
