When and how exactly does Ocean load its cxt files?
sanjeeb
Newbie level 5
Newbie level 5
India
cxt files for ocean
Hi
Can anyone help me in finding how ocean loads its cxt files ie. where is it specified to pick up these cxt files.
Basically when i run ocean i get the following result
Program: @(#)$CDS: awd.exe version 5.1.0 06/12/2004 01:38 (intelibm5.Cadence.COM) $
Hierarchy: /apps/eda/cadence/IC/cdsIC5141_orig/tools.lnx86/dfII/
Sub version: sub-version 5.10.41.169 (32-bit addresses)
X server: The X.Org Foundation
Depth of Visual (Root): 24 (24)
Number of Planes Used: 24
X version: 11.0 (vendor release 60802000)
Window Manager: other
User Name: skghosh
Working Directory: company156:/home/skghosh
Process Id: 18205
COPYRIGHT � 1992-2004 CADENCE DESIGN SYSTEMS INC. ALL RIGHTS RESERVED.
� 1992-2004 UNIX SYSTEMS Laboratories INC.,
Reproduced with permission.
This Cadence Design Systems program and online documentation are
proprietary/confidential information and may be disclosed/used only
as authorized in a license agreement controlling such use and disclosure.
RESTRICTED RIGHTS NOTICE (SHORT FORM)
Use/reproduction/disclosure is subject to restriction
set forth at FAR 1252.227-19 or its equivalent.
Loading auCore.cxt
Loading acv.cxt
Loading UltraSim.cxt
Loading oasis.cxt
Loading analog.cxt
Loading asimenv.cxt
Loading spectreinl.cxt
Loading hspiceD.cxt
Loading UltraSim/ADE cxt from "/apps/eda/cadence/MMS/7p11_239/tools.lnx86//ultrasim/etc/context/5.10.41"
$ UltraSim/ADE cxt version: 5.10.41.169 Oct 14 13:36:34 2009 $
Loading UltraSimMixi.cxt
Loading mmsimenv.cxt
Loading UltraSimVerilog cxt from "/apps/eda/cadence/MMS/7p11_239/tools.lnx86//ultrasim/etc/context/5.10.41"
$ UltraSimVerilog cxt version: 5.10.41.169 Oct 14 13:36:55 2009 $
Type ocnHelp() for help on OCEAN commands.
Look in .../tools/dfII/samples/artist/OCEAN for example
OCEAN scripts.
In which file or script is it specified to load these cxt files.
Can i run ocean without loading these cxt files.
regards
Re: cxt files for ocean
Look into .cdsinit or .cdsenv file(s) in your working and/or home directory. Follow up (possibly) further sourced init/environment files.
Presumably not.
