hemantMkumar
Newbie level 1
Issue:
'no error is found while running the code.
Scenario:
'If i am not adding .pdx/.cdd file into the canalyzer configuration file[.cfg] , and i run my code i can see the function callevent in canalyzer write window as soon as on press of my vb button [MsgSend_Click]
but the problem arises when i add .pdx/.cdd file no msg appears in the canalyzer write window..no exception in vb also...
Things i tried:
1-> i changed the program node location to analysis branch, it worked [.pdx/.cdd added in .cfg] but here in this case i cannot perform
read data identifier things.so i cannot go with this..
Pl help.........
below is the code:
Scenario:
Things i tried:
Pl help.........
below is the code:
Code Visual Basic - [expand] 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 Public WithEvents mCANalyzerApp As CANalyzer.Application Public WithEvents mCANalyzerMeasurement As CANalyzer.Measurement Public ExternFunc As CANalyzer.CAPLFunction Private Sub MeasurementInitiated() Try CANalyzerCAPL.Compile(Nothing) ExternFunc = CANalyzerCAPL.GetFunction("samplefun")'function is defined in capl Catch ex As Exception End Try End Sub Private Sub Form1_Load(ByVal sender As System.Object, ByVal e As System.EventArgs) Handles MyBase.Load Try mCANalyzerApp = New CANalyzer.Application mCANalyzerApp.Open("-path to .cfg", True, True) mCANalyzerMeasurement = mCANalyzerApp.Measurement AddHandler mCANalyzerMeasurement.OnInit, AddressOf MeasurementInitiated Catch ex As Exception End Try End Sub Private Sub start_Click(ByVal sender As System.Object, ByVal e As System.EventArgs) Handles Start.Click mCANalyzerMeasurement.Start() Private Sub MsgSend_Click(ByVal sender As System.Object, ByVal e As System.EventArgs) Handles MsgSend.Click Try TextBox1.Text = ExternFunc.Call()'call to capl function Catch ex As Exception End Try End Sub **********************************CAPL code********************************************* variables { } void samplefun() { Write("Hello in capl"); }
