qianxuan
Newbie level 3
I have run a VCO simulation by spectre. The VCO is a differential inverter with a pair cross-couple PMOS. Output frequency is about 1GHz when input vctl equals 705mV.
The problem is shown in attachment.
curve1:vctl=706mV,out=998MHz
curve2:vctl=710mV,out=985MHz
curve3:vctl=704mV,out=1.004GHz
There is only a little difference between vctl but the change of phase noise is huge, more than 60 dBc/Hz in worst case.
My question is why the spurs happen at 1, 2 and 4 times signal frequency and and why they change so much
