Sunny55
Full Member level 3
Hi, i am working on this circuit and the problem i faced is the relay does not shift and sometimes the relay also get 'confused'(Not working like it used to be). Here is the circuit. **broken link removed**
The relay i am using is a 12VDC 5 pins relay and power supply to the circuit is around 13VDC. The circuit works perfectly sometimes and then it does not work.
Can anyone please help me ?
Thanks
Sunny55.
I am using just R1 and R4( Pots R2 and R3 not used). Regarding the relay's switching problem, could it be the problem with the right side of the circuit?
Thanks
Sunny55.
