aqcy
Newbie level 3
Hi guys.. just found out bout this forum. Currently, i am working on a PWM. Using vhdl to generate a pwm to drive a DC motor.. I am using the Xilinx ISE 7.1i software. Below is my code.. i am pretty sure it will work.. but the funny thing is when i simulate using ISE simulator.. the outpwm signal is always 0... the pwm has an 8bit input.. i have tried setting the input to 32,64,128.. but still, pwm output is forever low..
i am getting desperate for a solution and this problem is driving me crazy..can someone please enlighten me?
[/code]
library ieee;
use IEEE.STD_LOGIC_1164.ALL;
use IEEE.STD_LOGIC_ARITH.ALL;
use IEEE.STD_LOGIC_UNSIGNED.ALL;
-- Interface definition
entity pwm_module is
port ( data: in STD_LOGIC_VECTOR (7 downto 0);
clk: in STD_LOGIC;
reset: in STD_LOGIC;
outpwm: out STD_LOGIC
end pwm_module;
architecture Behavioral of pwm_module is
signal int_reg: STD_LOGIC_VECTOR (7 downto 0);
signal counter: STD_LOGIC_VECTOR (7 downto 0);
signal tc: STD_LOGIC;
signal cnt_dir: STD_LOGIC;
begin
--store data into register
process(clk, int_reg, reset)
begin
if (reset = '1') then
int_reg <= "00000000";
elsif (rising_edge(clk)) then
int_reg <= data;
end if;
end process;
--8 bit up/down counter
process(clk, counter, tc, cnt_dir)
begin
if (tc = '1') then
counter <= int_reg;
if (tc = '0' and cnt_dir = '1' and counter < "11111111") then --if not end, count up and counter < 255
counter <= counter + 1;
elsif (tc = '0' and cnt_dir = '0' and counter > "00000000") then
counter <= counter - 1;
end if;
end if;
end process;
process(tc, counter, clk, reset)
begin
tc <= '1';
if ((counter = "11111111") or (counter = "00000000")) then
tc <= '1';
else
tc <= '0';
end if;
end if;
end process;
--generate pwm
process(clk, tc, reset)
begin
cnt_dir <= '0';
elsif (rising_edge(tc)) then
cnt_dir <= not(cnt_dir);
else
cnt_dir <= cnt_dir;
end if;
end process;
outpwm <= cnt_dir;
end Behavioral;
