[SOLVED] what's wrong with my PMOS code ??
romel_emperado
Advanced Member level 2
philippines
hi I want to do like this curve using hspice but it whatever I do I cant do something like this..
Image1:
this is my code for my PMOS:
PHP:
Title: PMos daw ni(not sure :) )
*Note the syntax: for the transistor,
*Mxxx drain gate source bulk MODEL_NAME L=x W=x
mp 0 gate source source pch w=2u l=10u
vgs gate 0  5
vds source 0 5
** sweep both Vds from 0 to 5 volts in increments of .2, and Vgs from 0 to 5 volts in increments of 1
.dc vds 0 5v .5 vgs 0 5 1
.option post
.prot
.lib 'rf018.l' tt
.unprot
.op
.plot i(mp)
.END
and the result of this code is this:
why is that the starting point of all the sweeps are in 0?
ok I will try
---------- Post added at 14:59 ---------- Previous post was at 14:57 ----------
no it's not.. not a pmos curve..
---------- Post added at 14:59 ---------- Previous post was at 14:59 ----------
any other trick to show the curve?
---------- Post added at 16:15 ---------- Previous post was at 14:59 ----------
the problem is all about the supply thing.. anyway here is the correct code
PHP:
TItLE: PMOS DAW
.param Supply=1.8
.options post
.global Vdd Gnd
Vdd Vdd Gnd 'Supply'
*** mpmos1 drain gate source bulk L= length W= width
m1 ds gs Vdd Vdd pch L=10u W=20u
* VoltageName Node+ Node- VoltageValue
vds Vdd ds 'Supply'
vgs Vdd gs 'Supply'
*increase Vds from 0 to 1.8v with step of 0.1 increase vgs from 0 to 1.8v with step of 0.5
.DC vds 0 5 .5 vgs 0 5 1
.probe dc i1(m1)
.lib 'rf018.l' tt
.END
Please dc sweep vds and use ".alter" to change vgs.
ps. .alter is a hspice command.
I haven't use .alter command
do you have the syntax of it?
---------- Post added at 03:46 ---------- Previous post was at 03:25 ----------
what do you mean by shift? something like this?
I used this line to sweep my VGS
