phatcreators
Full Member level 5
What's the working principle of a packing machine (packing up the cartons) ?
with a strip .... that joins the strip over the cartons
manually as we keep the button pressed the heating tool makes the join of the strip to pack the cartons .........
so what could be the problems then ? i already checked all the 3 limit switches .....
discrete transistor logic circuit or modules ? Could it be some transistor logic or module fault ???
which transistors and modules are used & how to test them out ??
the process is stopped in the midway ..... only heating element (tool) just comes forward only half way not till the end limit neither it returns back to complete the sequence
