Whats the substrate material used in LNB for SAT Ku band?
khouly
Advanced Member level 5
EGYPT
LNB substarte
what is the substarte material used in LNB for SAT for Ku band
is it duoriod
thanks
LNB substarte
Low-noise blocks LNB converters for satellite Ku-Band use materials like GaAs PHEMT which is pseudomorphic high-electron-mobility transistor technology materials. I do not know how they make them.
It is just custom materials for a low noise figure minimum of 0.5dB.
Re: LNB substarte
no i am asking about the PCB material used for tis frequency range
thanks
Re: LNB substarte
It's most likely to be some PTFE and fiber glass composite so via holes can be manufactured with reliability.
