Whats the problem with my two stage opa?
yihsiu
Junior Member level 1
help!!! two stage opa
could someone tell me
what 's the problem with my circuit?
vdd: 13 volt vss: -13 volt
i gave vin+ 14volt pulse and sine signal respectively
vin- 13.4 volt
i think the currect output waveform should be from 13 volt to -13 volt
but for my design the output did not swing and the pulse output signal was around 0 to 12 volt
could someone tell me please
thank you very much
Re: help!!! two stage opa
your miller cap feedback should go the the drain of the input transistor, not source.
Hi noiseless
i tried but the output still didn't go to swing
make sure the bulk connect of nmos is vss
it looks that the bottom of the schematic should be ground, not Vdd
