What's the parameters should be simulated during design VCO?
holddreams
Full Member level 6
Full Member level 6
Shanghai
That is ,which parameters should be considered thoroughly?
THANKS.
Re: What's the parameters should be simulated during design
jitter and phase noise in a vco are usually the critical parameters but then it depends on your spec. what is the most stringent constraint.
Hi:
If you are using LC-VCO, with MOS varactor tuning, parameters such as phase noise, VCO sensitivity, output power level, frequency pushing, frequency pulling and tuning percentage is of importance.
Rgds
