What's the mininum PLL phase margin for the loop to work properly?
gpwu
Member level 2
Member level 2
What's the mininum PLL phase margin in order to for the loop work properly?
I designed one which is around 35 degree and it seems to work fine.
Re: PLL phase margin
I think 45 degree is needed, 60 degree is better.
Sometimes your simulation can not reflect the practical condition.
i wanted to know on what basis u are saying 45 degree or 60 degree phase margin is required./....can u explain in detail
basically you want the system to have a good dampling factor. 45-60 degree is a good number such that there is not much overshoot
PLL phase margin
for phase system you just need think 180 is enough
    gpwu
PLL is 2 or more poles system, it has the damping problem.
PLL phase margin
stability and band width will be effected by the phase margine
also if you are using the passive filter than the value of the res and the cap will depand and hence the area of the chip.
damping factor also effect the settling time
hence think about the factors.
PLL phase margin
thank you guys for your help..this is a good forum.
Hope I'll post some better questions next time.
35 is impossble, you have done a wrong calculation
