ricklin
Member level 4
Hi, All
I've designed a buffer for a reference voltage in standard CMOS process. The buffer used a 2-stage miller compensation opamp followed a source follower (the follower feed back to opamp neg), and the output is a follower replica.
My problem is that if using MOSFET as the compensation cap, I can save area and big metal wire pathes ( If use MOM caps, the metal line esp power and ground will be blocked). As a replica architecture, the feedback loop itself is seldom disturbed.
So what's the drawback of MOSFET compensation? Especially that can not be shown by simulations both AC and tran.
Best Regards
Best Regards
