Enshuo
Junior Member level 2
Hi experts,
As far as I know, the major difference is the data rate. The data rate of SPI is 10-20Mbps, QSPI is four times to 80Mbps, but the clock frequency of them are the same 25Mhz. QSPI doesn't require CPU intervention.
If I change a flash from SPI to QSPI, what else should I take care of? QSPI has four more pins, etc. Software or firmware are needed to modify as well?
