guybrush
Junior Member level 3
SERIAL RECEIVER
I'm designing an ACTEL A54SX FPGA for control and monitoring of a power board, implementing two serial interfaces very slow (19200 bit/s, with parity) and some digital I/O. On the board i have a 8MHz clock, so I have to divide it down to 8x19200, that will be the higest frequency in the serial receiver.
This are my different solutions:
1) I use the 8MHz clock as HCLK, all design is synchronous and I produce the CE for 19200 and 8x19200 using suitable counters.
2) I divide the 8MHz system clock down to 8x19200, the output of this counter will be the clock used into the FPGA routed with CLKA or CLKB.
3) I use the CLKA input for the 8MHz system clock, I divide down the frequency to 8x19200 that is routed out of the FPGA and then back thru HCLK. Then synchronuos design.
Which is the best solution in your opinion?
