What's better for electrical engineer: Java or C# ?
borun
Newbie level 5
Newbie level 5
Do you recommend me to learn java or c# as a computer backgrounded electrical engineer=?
Help:)
Java or c# ?
I would go for C#. It is a very modern language with some nice features. It is closley tied to the net framework, but that does not tie you into using windows os.
The net framework theoreticaly will work with any os.
Re: Java or c# ?
I would also choose c#,unless i wanted to port my program to Linux.
If you know c++ then C# will not be difficult to learn,but there is a lot to learn for .net framework.All these classes and methods make me dizzy.
+you have msdn,which provides info about everything so dont worry about getting stuck anywhere.
Re: Java or c# ?
Java can be used on all major OS's. Both are good to learn. C is also important for microcontrollers. And learning VHDL or Verilog of some kind of HDL is almost as important to learn since FPGA's and other types of programmable integrated circuits are big and getting bigger in electrical engineering.
Re: Java or c# ?
so far i think that you must learn C language instead of java because its easy and have lot of applications on the other hand java is even case sensitive and may bother you rest of it is up to you
Re: Java or c# ?
i would recommend c# with dot net coz it is easy to learn for no IT students.Though it is coding compared to jave it is easy to learn. so learn C#.
Re: Java or c# ?
I agree with you "jhbbunch" and i would like to add some information which is JAVA is a full OOP.
-------------My favorites PC interfacing ---------------------------
www.embedded-hardware.com
